I think it’s something really easy, but I must confess my innate difficulty to write rules and code!
I’m writing an screenplay and would like to have an atribute, which I will call $Time, where I would have the moment in minutes when the scene happens. I’m have already an atribute called $Duration where I designate a number of minutes for each scene. To find the value of $Time I just have to add the value of $Time in the last item in the outline with the actual value of $Duration in the scene I’m working.
It’s simple but I must confess I don’t know where to start!
all notes used the rule are siblings, i.e. children of the same container, as inferred from above. * the note order, as seen in outline view, is the order in which the scenes play out from first to last.
If the above assumptions are not true , please provide details of the overall arrangement of the notes.
A problem with the previously suggested note is that if $Duration == 0 the application of the rule in that and the subsequent notes gets confused and the rules do not provide the desired answer. The suggested rule also works faster and makes rearranging notes more reliable from the perspective of the time/duration results.
