Calendar like view?
Hi TBX’ers,
A search simply yields too many results, so I’ll just quickly ask:
  • Tinderbox has a lot of ways of working with dates
  • Tinderbox has its timeline view
Searching for ‘simple’ Calendar integration, possibly even with sync (Calendar, Omnifocus):
Is there some (incorporated) way to show a Calendar grid? (Without building it all from scratch…)
Thanks for pointing me into the right direction!
Hmm, not sure, but I think $Modified and $Created are specific to TBX notes.
What if you want to copy / add / sync macOS Calendar.app entries?
FWIW, I tried to search Atbref, but it seems search is not functioning… (I’ll try rebooting first…)
On Calendar planning grids: https://vimeo.com/381819281
