Copying a list of all attribute:value pairs for the selected note
Not sure if this will be of use to anyone else - I’m find it useful for exploring what’s there.
(Can be run, for example, from Script Editor, with the language tab at top left set to JavaScript - I personally run scripts more often from Atom or Keyboard Maestro etc)
    'use strict';
    // Copy to clipboard a list of all the non-empty (attribute: value)
    // pairs for the selected Tinderbox 8 note .
    // ver 0.03
    const main = () =>
        either(
            x => x,
            x => (
                standardAdditions().setTheClipboardTo(x),
                console.log(x),
                x
            bindLR(
                frontDocLR(),
                d => bindLR(
                    selectedNoteLR(d),
                    note => Right(unlines(sort(concat(zipWith(
                        (k, v) => 0 < v.length ? [
                            k + ': ' + v
                        note.attributes.name(),
                        note.attributes.value()
    // TINDERBOX FUNCTIONS --------------------------------
    // frontDocLR :: Tbx IO () -> Either String Tbx Doc
    const frontDocLR = () => {
        // Either the front document in Tinderbox 8, or an
        // explanatory message if no documents are open,
        // or Tinderbox 8 is not running.
        const tbx = Application('Tinderbox 8');
        return tbx.running() ? (() => {
            const ds = tbx.documents;
            return 0 < ds.length ? (
                Right(ds.at(0))
            ) : Left('No documents open in Tinderbox');
        })() : Left('Tinderbox 8 is not running.');
    // selectedNoteLR :: Tbx Doc -> Either String Tbx Note
    const selectedNoteLR = doc => {
        // Either the first selected note, or an
        // explanatory message if nothing is selected.
        const note = doc.selectedNote();
        return note !== null ? (
            Right(note)
        ) : Left('No note selected in ' + doc.name());
    // JXA ------------------------------------------------
    // standardAdditions :: () -> Application
    const standardAdditions = () =>
        Object.assign(Application.currentApplication(), {
            includeStandardAdditions: true
    // GENERIC FUNCTIONS ----------------------------------
    // Left :: a -> Either a b
    const Left = x => ({
        type: 'Either',
        Left: x
    // Right :: b -> Either a b
    const Right = x => ({
        type: 'Either',
        Right: x
    // bindLR (>>=) :: Either a -> (a -> Either b) -> Either b
    const bindLR = (m, mf) =>
        undefined !== m.Left ? (
            m
        ) : mf(m.Right);
    // concat :: [[a]] -> [a]
    // concat :: [String] -> String
    const concat = xs =>
        0 < xs.length ? (() => {
            const unit = 'string' !== typeof xs[0] ? (
            return unit.concat.apply(unit, xs);
    // either :: (a -> c) -> (b -> c) -> Either a b -> c
    const either = (fl, fr, e) =>
        'Either' === e.type ? (
            undefined !== e.Left ? (
                fl(e.Left)
            ) : fr(e.Right)
        ) : undefined;
    // Returns Infinity over objects without finite length.
    // This enables zip and zipWith to choose the shorter
    // argument when one is non-finite, like cycle, repeat etc
    // length :: [a] -> Int
    const length = xs =>
        (Array.isArray(xs) || 'string' === typeof xs) ? (
            xs.length
        ) : Infinity;
    // sort :: Ord a => [a] -> [a]
    const sort = xs => xs.slice()
        .sort((a, b) => a < b ? -1 : (a > b ? 1 : 0));
    // take :: Int -> [a] -> [a]
    // take :: Int -> String -> String
    const take = (n, xs) =>
        'GeneratorFunction' !== xs.constructor.constructor.name ? (
            xs.slice(0, n)
        ) : [].concat.apply([], Array.from({
            length: n
            const x = xs.next();
            return x.done ? [] : [x.value];
    // unlines :: [String] -> String
    const unlines = xs => xs.join('\n');
    // Use of `take` and `length` here allows zipping with non-finite lists
    // i.e. generators like cycle, repeat, iterate.
    // zipWith :: (a -> b -> c) -> [a] -> [b] -> [c]
    const zipWith = (f, xs, ys) => {
        const
            lng = Math.min(length(xs), length(ys)),
            as = take(lng, xs),
            bs = take(lng, ys);
        return Array.from({
            length: lng
        }, (_, i) => f(as[i], bs[i], i));
    // MAIN ---
    return main();
Or, FWIW, an AppleScript version:
use AppleScript version "2.4"
use framework "Foundation"
use scripting additions
-- RobTrew (Twitter @complexpoint) 2019
-- https://github.com/RobTrew
-- ver 0.01
-- TINDERBOX 8:
-- COPY ALL NON-EMPTY (ATTRIBUTE: VALUE) PAIRS OF
-- SELECTED NOTE TO CLIPBOARD
on run
        script go
            on |λ|(x)
                tell attributes of x
                    script kv
                        on |λ|(k, v)
                            if "" ≠ v then
                                {k & ": " & v}
                            else
                            end if
                        end |λ|
                    end script
                    my |Right|(my unlines(my sort(my concat(my zipWith(kv, name, value)))))
                end tell
            end |λ|
        end script
    end tell
    script clip
        on |λ|(x)
            set the clipboard to x
            return x
        end |λ|
    end script
    return either(|id|, clip, ¬
        bindLR(bindLR(frontDocLR(), selectedNoteLR), go))
end run
-- TINDERBOX FUNCTIONS ------------------------------------
-- frontDocLR :: Tbx IO () -> Either String Tbx Doc
on frontDocLR()
    -- Either the front document in Tinderbox 8, or an
    -- explanatory message if no documents are open,
    --  or Tinderbox 8 is not running.
        if running then
            set ds to documents
            if 0 < (count of documents) then
                my |Right|(item 1 of documents)
            else
                my |Left|("No documents open in Tinderbox 8")
            end if
        else
            my |Left|("Tinderbox 8 is not running.")
        end if
    end tell
end frontDocLR
-- selectedNoteLR :: Tbx Doc -> Either String Tbx Note
on selectedNoteLR(doc)
    -- Either the first selected note, or an
    -- explanatory message if nothing is selected.
        set oNote to selected note of doc
        if missing value is not oNote then
            my |Right|(oNote)
        else
            my |Left|("No note selected in " & name of doc)
        end if
    end tell
end selectedNoteLR
-- GENERIC FUNCTIONS --------------------------------------
-- https://github.com/RobTrew/prelude-applescript
-- Left :: a -> Either a b
on |Left|(x)
    {type:"Either", |Left|:x, |Right|:missing value}
end |Left|
-- Right :: b -> Either a b
on |Right|(x)
    {type:"Either", |Left|:missing value, |Right|:x}
end |Right|
-- bindLR (>>=) :: Either a -> (a -> Either b) -> Either b
on bindLR(m, mf)
    if missing value is not |Right| of m then
        mReturn(mf)'s |λ|(|Right| of m)
    else
        m
    end if
end bindLR
-- concat :: [[a]] -> [a]
-- concat :: [String] -> String
on concat(xs)
    set lng to length of xs
    if 0 < lng and string is class of (item 1 of xs) then
        set acc to ""
    else
        set acc to {}
    end if
    repeat with i from 1 to lng
        set acc to acc & item i of xs
    end repeat
    acc
end concat
-- either :: (a -> c) -> (b -> c) -> Either a b -> c
on either(lf, rf, e)
    if isRight(e) then
        tell mReturn(rf) to |λ|(|Right| of e)
    else
        tell mReturn(lf) to |λ|(|Left| of e)
    end if
end either
-- id :: a -> a
on |id|(x)
    x
end |id|
-- isRight :: Either a b -> Bool
on isRight(x)
    set dct to current application's ¬
        NSDictionary's dictionaryWithDictionary:x
    (dct's objectForKey:"type") as text = "Either" and ¬
        (dct's objectForKey:"Left") as list = {missing value}
end isRight
-- length :: [a] -> Int
on |length|(xs)
    set c to class of xs
    if list is c or string is c then
        length of xs
    else
        (2 ^ 29 - 1) -- (maxInt - simple proxy for non-finite)
    end if
end |length|
-- min :: Ord a => a -> a -> a
on min(x, y)
    if y < x then
        y
    else
        x
    end if
end min
-- Lift 2nd class handler function into 1st class script wrapper
-- mReturn :: First-class m => (a -> b) -> m (a -> b)
on mReturn(f)
    if script is class of f then
        f
    else
        script
            property |λ| : f
        end script
    end if
end mReturn
-- sort :: Ord a => [a] -> [a]
on sort(xs)
    ((current application's NSArray's arrayWithArray:xs)'s ¬
        sortedArrayUsingSelector:"compare:") as list
end sort
-- take :: Int -> [a] -> [a]
-- take :: Int -> String -> String
on take(n, xs)
    if list is c then
        if 0 < n then
            items 1 thru min(n, length of xs) of xs
        else
        end if
    else if string is c then
        if 0 < n then
            text 1 thru min(n, length of xs) of xs
        else
        end if
    else if script is c then
        set ys to {}
        repeat with i from 1 to n
            set v to |λ|() of xs
            if missing value is v then
                return ys
            else
                set end of ys to v
            end if
        end repeat
        return ys
    else
        missing value
    end if
end take
-- unlines :: [String] -> String
on unlines(xs)
    set {dlm, my text item delimiters} to ¬
        {my text item delimiters, linefeed}
    set str to xs as text
    set my text item delimiters to dlm
    str
end unlines
-- zipWith :: (a -> b -> c) -> [a] -> [b] -> [c]
on zipWith(f, xs, ys)
    set lng to min(|length|(xs), |length|(ys))
    if 1 > lng then return {}
    set xs_ to take(lng, xs) -- Allow for non-finite
    set ys_ to take(lng, ys) -- generators like cycle etc
    set lst to {}
    tell mReturn(f)
            set end of lst to |λ|(item i of xs_, item i of ys_)
        end repeat
        return lst
    end tell
end zipWith
I have trouble following the AppleScript, but here’s what I think is a rough translation into a more pedestrian dialect. Really appreciated learning how to do one-line sort!
	try
		tell front document to tell first selection
			set {attrNamesLst, attrValsLst} to {name of attributes, value of attributes}
		end tell
	on error
		error "Select a Tinderbox note"
	end try
end tell
set pairLst to {}
repeat with i from 1 to length of attrNamesLst
	tell item i of attrValsLst to if it is not "" then ¬
		set end of pairLst to item i of attrNamesLst & ": " & it
end repeat
set sortedLst to ((current application's NSArray's arrayWithArray:pairLst)'s ¬
set text item delimiters to return
set the clipboard to sortedLst as string
return sortedLst as string -- to view in Script Editor result pane
It’s possible that you may find one or two other useful things in the library which that comes from.
If you are curious about snapping together these pre-existing ‘lego-blocks’ of Applescript code to build small tools for Tinderbox, then the first functions to experiment with are probably map, filter and foldl (reduce):
Examples, FWIW: (click to expand the source code)
-- MAP, FILTER, FOLD/REDUCE
-- (Applescript examples)
on run
    -- MAP ------------------------------------------------
    map(dbl, {1, 2, 3, 4, 5})
    --> {2, 4, 6, 8, 10}
    map(toUpper, {"alpha", "beta", "gamma"})
    --> {"ALPHA", "BETA", "GAMMA"}
    map(odd, enumFromTo(1, 10))
    --> {true, false, true, false, true, false, true, false, true, false}
    -- FILTER ---------------------------------------------
    filter(odd, enumFromTo(1, 10))
    --> {1, 3, 5, 7, 9}
    filter(even, enumFromTo(1, 10))
    script longer
        on |λ|(x)
            4 < length of x
        end |λ|
    end script
    filter(longer, {"alpha", "beta", "gamma", "delta", "epsilon", "zeta", "eta"})
    --> {"alpha", "gamma", "delta", "epsilon"}
    -- FOLD / REDUCE (here fold left: foldl) --------------
    foldl(plus, 0, enumFromTo(1, 10))
    --> 55
    foldl(mul, 1, enumFromTo(1, 10))
    -- 3628800
    foldl(max, 0, {81, 27, 25, 64, 121, 16, 100})
    --> 121
end run
-- Sample functions ---------------------------------------
on dbl(x)
    2 * x
end dbl
on plus(a, b)
    a + b
end plus
on mul(a, b)
    a * b
end mul
on max(a, b)
    if b > a then
        b
    else
        a
    end if
end max
-- GENERIC ------------------------------------------------
-- enumFromTo :: Int -> Int -> [Int]
on enumFromTo(m, n)
    if m ≤ n then
        set lst to {}
        repeat with i from m to n
            set end of lst to i
        end repeat
        return lst
    else
        return {}
    end if
end enumFromTo
-- even :: Int -> Bool
on even(x)
    0 = x mod 2
end even
-- filter :: (a -> Bool) -> [a] -> [a]
on filter(f, xs)
    tell mReturn(f)
        set lst to {}
            set v to item i of xs
            if |λ|(v, i, xs) then set end of lst to v
        end repeat
        return lst
    end tell
end filter
-- foldl :: (a -> b -> a) -> a -> [b] -> a
on foldl(f, startValue, xs)
    tell mReturn(f)
        set v to startValue
            set v to |λ|(v, item i of xs, i, xs)
        end repeat
        return v
    end tell
end foldl
on mReturn(f)
        f
    else
        script
            property |λ| : f
        end script
    end if
end mReturn
-- map :: (a -> b) -> [a] -> [b]
on map(f, xs)
    tell mReturn(f)
        set lst to {}
            set end of lst to |λ|(item i of xs, i, xs)
        end repeat
        return lst
    end tell
end map
-- odd :: Int -> Bool
on odd(x)
    not even(x)
end odd
-- toUpper :: String -> String
on toUpper(str)
    set ca to current application
    ((ca's NSString's stringWithString:(str))'s ¬
        uppercaseStringWithLocale:(ca's NSLocale's currentLocale())) as text
end toUpper
