I must be missing something very basic, but I can’t figure this out. How can I rename / delete a save filter (outline view)?
Select the filter (if not already active).
Choose Save Filter… from the action menu.
Press Delete, or change the name and press Save
Thanks. Thought it would be there, but it seems not to be working:
- if I press delete, nothing happens;
- if I change the name and press save, a new filter is created with the new name, but the old is not deleted.
We’ll look into this when the emergency abates slightly.
This appears to still be an issue - no way to delete a filter
The delete button still doesn’t appear to work in version 9.7. Is this the case or am I doing something wrong?
It broke again, seemingly! We’ll sort it out for the next update.
Excellent. Thank you for your quick reply, Mark.
