prenez
(Michael Prenez-Isbell)
April 23, 2018, 10:42pm
1
Ok, I have to go back to school. Clearly the loop is finding the note ‘tool’. It shows up in the variable $found.
But the equality test never sets $notename to ‘tool found’ no matter what I do. Help!
NoteListt is of list type, found is a string, notename is a string.
When I set the test to inequality, !=, the string $notename is set to ‘tool found’.
prenez
April 23, 2018, 10:53pm
2
This doesn’t work either.
@mwra
prenez
April 24, 2018, 1:44am
3
we’re good. think it was the smart quotes. you kinda have to get everything right. I remember that now :-/ When you have code that works make ten copies of it. And: if it’s not working, toss the broken code and build it from scratch.
@mwra
galen
(Galen Menzel)
April 24, 2018, 1:46am
4
It’s a good idea to use the built-in Code
prototype for this sort of thing, which disables smart quotes in its text field.
Example here (56.8 KB) for posterity.
prenez
April 24, 2018, 2:17am
5
great. I was doing a ton of action code programming 2014 but forgot almost everything. thanks.
