I’ve posted a series of basic examples of text export.
If you’ve ever exported anything using a template, these posts probably aren’t for you. But if you’ve never made or customized a template, they might be.
Thanks, I think we can’t have too many examples - if only because what’s simple or makes sense varies from person to person.
These are great posts ! This is the first time I understand something to the syntax for templates ! Very pedagogical. Thank you so much !!
Yes, thanks very much, these are very clear, instructive, and helpful.
Thanks all. Glad they’re helpful
