I have a 2019 MBP with 64 GB of RAM. Right now I’m running 10.15.6, but plan on upgrading to Big Sur unless someone cautions me not to. I am running TB 8.9.1.
I have a TBX document with ~500 notes (data items) from which I have ziplinked quotes to create another 1500 notes (data extracts). The file is at 20MB right now. I want to run agents to explore the relationships among the 1500 data extracts. Often times this means creating agents that crawl all 1500 notes and assign them to smart adornments. These adornment queries may be on various user-defined attributes or based on system attributes like Tags or Flags. A common agent would be mapping, say, 250 notes across 86 smart adornments, another common agent might map 400 notes across 5 adornments. Right now these agents/smart adornments do not have actions, but they could (more likely I’d do the $AgentAction bits in the attribute browser).
I can easily imagine having a hundred or so agents in this file. But I can also creatively work around this to avoid it. I’ve never been so query-based in my TBX files, so I’m not sure what’s asking too much of the software/system.
I’ve gotten into some troublesome loops with TB so far, where the app maxes out my CPU and crashes or becomes unresponsive, but so far I think it’s always because there’s been an error in my code. (Side question: how do I stop TB from trying to open a file that crashed it upon restart? I get into a situation where launching TB means automatically trying to re-open the file that was opened when it became unresponsive and so it immediately becomes unresponsive again. Te only thing that seems to work is to uninstall TB so the preferences reset and then reinstall to get it to “forget” to open the crashed file.)
Your advice/perspective is most appreciated!
