How to get it to accept registration
(Andrew) #1
I am using tinderbox 5. I had to stop using it with High Sierra because it didn’t work. However I am now on Mojave beta and it seems to be working again.
The only problem is I can’t get it to accept my registration code. I put in my username and code and the tick remain red coloured and never turns green.
Any ideas how to do make it accept registration?
(Mark Anderson) #2
Contact tech support.
(eastgate) #3
Tinderbox 5 is between 4 and 8 years out of date, depending on which version you want to use.
If your last update includes the final Tinderbox 5 release, Tinderbox 5.12.3 http://www.eastgate.com/download/tbx5123a.dmg should help.
