Identifying the outgoing links of a given node?
(RobTrew) #1
Any advice on identifying the outgoing links of a given node ?
In the absence of direct access to map links through the osascript (Apple|JavaScript) API, presumably the trick is to
  • script the definition of a temporary agent in terms of links() and
  • read the list of children which it harvests ?
(eastgate) #2
That would work. If there’s need, we could support read-only properties of notes — perhaps something like
set a to outbound destinations
set b to inbound sources
(RobTrew) #3
That would be excellent – direct access of that kind (from the osascript API) to the graph formed by a set of links would be very helpful for some of the data translations (and map view geometric shortcuts) that I would like to script.
