As I understand it the $OutlineOrder attribute – as its name implies – only gives the sequentially integer-numbered position of a note irrespective of its outline depth.
I was hoping that I could find (or code) an attribute that, in conjunction with a $DisplayName = rule, would assign automatically updating outline numbering prefixes to note names (in outline view) along the lines of
First Main Heading
Second Main Heading
2.1 Subheading A
2.2 Subheading B
Third Main Heading
3.1 Subheading C
3.1.1. Sub-subheading
(I’m not bothered about the formatting of the outline ordering – Harvard, whatever is fine)
In case this is an example of an xy problem, I should explain that as well as providing some formatting I’m actually planning to use this attribute to assign a large number of atomic notes to the outline (i.e. the atomic notes would have user-assigned values for a $TopicIndex attribute and the Heading notes in the outline would query for atomic notes with $TopicIndex == their outline number). I hope that makes sense…
I’ve done something like this with a Rule that looks at the outline level of the parent and prepends that to the current note’s outline level – with whatever formatting is desired.
Add this to a prototype you’ll use for all numbered notes first un-checking ‘Enabled’ for the rule or edict using either of those. I’d recommend an edict as you can alway force update an edict, e.g. if you move or delete a note.
Add a String-type user attribute ‘TopicNumber’ to you prototype
Also in the prototype select the Text Inspector and un-check ‘Enabled’ for the Display Expression, then add this code:
$TopicNumber+" "+$Name
Also set the OnAdd action of your prototype (here mine is called “Task”) like so:
Prototype|="Task";
Lastly ensure all you prototype, template, etc., folders are at the end of the root container so your first content note is sibling #1. The result is like this:
But let’s say you want the number to be under a root container. It still works, as long as the parent (not using the prototype) has no $topicNumber value:
As the code runs of values from the parent of the numbered note, the same prototype can populate more than one discrete set of numbering:
If you only want a trailing period that’s likely possible too, though it might make usage not as flexible as above. But, I’ll leave that as an exercise for someone else to try.
