It’s not possible to have a note’s caption be coded in a dynamic way, correct?
What do you mean by dynamically code, Beck?
You can definitely change the caption using stamps, rules and edicts, but is there something else you mean? I don’t think they change without some trigger though (like clicking outside the note, changing the view etc, rather than continually updating).
Am I misunderstand what you’re after?
David.
I was after putting something like the Rule query you used for your illustration into the Caption box, like so:
But this’ll definitely work!
(What I’m after in this instance is putting the $AgentQuery as the caption to the agent. It’d be neat to just have this be automatic, say in an agent Prototype.)
Thanks, David!
If you add to the code:
$CaptionFont=$CodeFont;
Then for this agent (only) the caption will change to a monospace font making it easier to read the code.
I’m glad it helped!
Nice touch!
Of course other fonts are available, but you get the idea.
