Hi,
Is it possible to link between notes of different TBX files?
If yes, what’s the way to create / write out such a “linked” note?
Thanks!
Erwin
Hi,
Thanks!
Erwin
What I recommend is
… and so on.
These are URL links – the only kind possible at this time for inter-document linking – they are not hyperlinks or internal Tinderbox links.
Thanks for replying Paul, I’ll see if I can get that going. If I have any more questions I’ll report back here.
Erwin
@PaulWalters
Hallo Paul,
First: “Copy Note URL” from a note.
Second: a semicolon appears at the end of the URL.
Example: tinderbox: // Screenwriter? View = map + selection = 1557460538;
Sometimes I have to delete the semicolon to achive it a clickable link.
What does that mean?
201905102
If the URL from the left note is inserted here
(with the context menu “Copy Note URL”)
there is a semicolon at the end.
But the URL is not yet clickable
tinderbox://_tTBX%20-980-010-%20why%20does%20TBX%20has%20a%20semicolon%20at%20the%20end%20of%20the%20URL%3F%20-%20201905102/?view=map+select=1557573342;
after the semicolon is erased then the URL is going to blue color and it is now clickable as a link.
Question:
How is this right side called?
Thanks,
Bernhard
201905102
