Hi All, is there a way to link from a note in one container to a note in a different container in map view?
When I try parking the link of the original note, once I leave the container I can’t seem to access the parked link and the link becomes whatever container I go to.
Thank you. I finally got this to work but it’s a bit inconsistent - sometimes when I go to drag the link from the parking space - the link has become the container – could this be happening if I’m not holding the link in the parking space long enough? Trying to figure out what I might be doing wrong when it doesn’t work.
Can you give the steps to re-create. I.e. doing each step and recording it at the timer rather than from memory. I know, from doing it, this feels like a PITA, but sometimes the process flushes the (likely) edge case you are tripping on. Or, do a video showing the problem/
OK - my apologies - I think I figured out what I was doing - I was using the parking space in the left hand part of the right pane rather than the one all the way in the upper left hand corner and I was being inconsistent with which of those dots (parking spaces) I was dragging the original link to.
