Move Splitter attribute-text pane
(Randall Morris-Ostrom) #1
The text pane is divided into an attribute section at the top, which contains pre-selected fields that are selected, and then there is a section for unstructured text below.
Is there a way to change the size of the fields (attributes) section? Currently, it is so small I cannot even read the key attributes I’ve selected to be there.
Thank you.
Randall
(Eric Brown) #2
The attribute text size can be changed using the Window–>Key Attributes menu (see attached photo).
(Mark Anderson) #3
Further to @EricB’s reply, the size setting shown in his screen-grab is stored in a Number-type System Attribute $KeyAttributesFontSize, so if necessary you can set it to a point size other than the 3 pre-defined values listed in the UI menu (i.e. those as in the grab above).
See also Key Attributes Table.
