Note title and Display expression
(Mariano Iannuzzi) #1
Hello to all TBxers,
I am working on a TB file to gather information about contacts and clients. As you will see in the attached screen capture, the note remains “untitled” even though I set the Display Expression as $FullName. I am not sure what I am doing wrong, but I intended to set the note title to match the name of the person.
The prototype also includes a set of rules to populate the subtitle and the note’s badge.
if($Organization!=0){$Subtitle=$Organization+" | "+$JobTitle;};
if($Gender==“male”){$Badge=“aaron”;};
if($Gender==“female”){$Badge=“Amy”;};
Thank you very much for your help!
Cheers
Mariano
(Paul Walters) #2
$DisplayExpression does not change $Name, it changes what is displayed instead of $Name in maps, outlines and other views. So, in your example, your note is displayed correctly in the map in your screenshot – in other words, $FullName is shown rather than $Name in that note on the map.
The string “untitled” appears above the key attributes table because that is where $Name is displayed. In other words, you have no errors – Tinderbox is working as designed. If you want something other than “untitled” to show above the KA list, then change the value of $Name.
(Mariano Iannuzzi) #3
Thank you, @PaulWalters
I did not know the difference between the two properties. Setting $Name = $FullName as a rule does do the trick.
Cheers
Mariano
(Mark Anderson) #4
To clarify further, see also $DisplayName.
Views (and many dialogs) show the note’s $DisplayName. The note’s text pane always shows the actual $Name.
$DisplayName holds the output from $DsisplayExpression, if there is one, or else it is the same as $Name.
