Notes fail to change after their prototypes are modified
I have a fairly complex doc with a lot of prototypes. I recently realized that I needed to add some key user-defined attributes to one of those prototypes, which I use a lot. One of the glories of Tinderbox is that I’m not penned in by decisions I made months ago about such things.
But when I turn to some older notes that take that prototype, they have not changed to reflect the changes I made in the prototype. The new attributes I created, which are in the prototype and which appear in a new note that takes it, do not appear in older notes. They still present key attributes of the older version of the prototype.
This is not a case of Tinderbox protecting some KA values from being modified. These new KAs are empty in the revised prototype and so I expected them to appear in all notes that take that prototype, regardless of when the notes were created.
I’m puzzled as to what I might have misunderstood here.
Tinderbox 8.2.1 on Mac 10.15.2 on a 2018 Macbook Air.
All and any thoughts welcome!
David
A note inherits its values unless it has a value of its own. Thus, if an old notes already has a value of (say) $KeyAttributes, that value overrides inheritance. So, if your old notes already have some value of $KeyAttributes, Tinderbox assumes that’s the value you want for that note.
You can remove an existing value with a stamp action
  $KeyAttributes=;
or with Quickstamp, or various other ways.
Thanks, Mark. Does that mean I have to do this note-by-note, value-by-value? What I want is to add some Key Attributes to older notes, via the prototype. I don’t see a way to tell TInderbox to do that all at once, for all old notes that so far lack those KAs.
Doing it note-by-note seems to defeat the purpose of using a prototype, but maybe I am missing something.
David
Is it easy to select all those notes? If so, select them and reset the value with Quickstamp or a stamp.
Or, use a stamp to remove the old $KeyAttributes and set the prototype in one step.
If you think about it, this is necessary for inheritance to be useful at all: otherwise, notes with a prototype would simply be aliases of the prototype!
Some useful further references re inheritance discussed above:
There are so many powerful searching and filtering tools available within Tinderbox, that it should be possible to do this in an automated way–if the numbers are large enough that it’s too much of a chore to do them one-by-one.
Here are the basic approaches that occur to me, which you probably already have in mind:
  • An agent that will search for the ones you’re looking for – using criteria of $Created before a certain date, or existing $Prototype meeting some search standard, or $KeyAttributes containing or excluding some value, or $hasLocalValue($AttributeName) being true (rather than inherited) – or some combination thereof. Then you could have the Action for that agent being re-setting the prototypes (or the Key Attribute values) first to the default value, and then to the new one you want. Eg, as @mwra and @eastgate have set out in their notes, doing a sequence of $Prototype=; (to reset to default) then $Prototype="new value"
  • You could also use the similarly powerful query feature in the Attribute Browser (which uses the same language as agent queries, as far as I’m aware) to produce a display of the notes in question. I don’t think you can do a Select-and-Quickstamp operation on those results within the AB itself. But you would have a sense of which notes you were looking for.
  • Using approach one, of an Agent to find the notes you’re looking for. But then, rather than an Action to automatically shift all the notes it discovers, you could create a Stamp or Quickstamp, to be able to inspect the results and de-select any of them you’re not really looking for.
Good luck; many tools. If I’ve messed up the details, one of the experts can set us both straight!
