I’m a tinderbox newer. I have many notes in my documents, and the following is my first look in chart mode. Anything is ok.
But when I open the note “阅读”, the notes overlap.
I can’t replicate this ( did include trying notes with non-Roman characters as are depicted above). Does the overlap occur when you first open the document, or after a specific event, e.g. changing tab or view type? Does it occur only in this document, or in all your documents?
I would suggest sending the document to Tinderbox support (info@eastgate.com) with notes as to how to recreate the effect illustrated.
We’re aware that the chart layout algorithm sometimes gets confused in this way. Diagnostic cases are very welcome
