Hi, setting shortcuts doesn’t work correctly.
Tinderbox shows shortcuts also in its contextual menu (I guess due to a request), although Apple’s Human Interface Guidelines suggest to don’t do that:
Show keyboard shortcuts in menu bar menus, not contextual menus. Contextual menus are already shortcuts to task-specific commands; it’s redundant to display keyboard shortcuts too.
I’m fine with showing them there, in fact I find it a good way to learn my new shortcuts. However, a successfully assigned shortcut, i.e. it’s picked up in the menu bar menu, doesn’t show the correct shortcut in the contextual menu.
This is all tested with restarting Tinderbox to pick up the changes:
- if I set
Make AliastoCMD+Kthe contextual menu showsCMD+L - if I set
Make AliastoALT+Kthe contextual menu showsALT+L - and so on
It’s quite confusing to see those wrong shortcuts in the contextual menu. @eastgate Could this be fixed?
