HI,
I store TB Documents in MYDocuments\TB Folder which is in sync via iCloud
- I use my MACMINI which is my work PC , I work on it till 11AM adding approximately 55 notes in a file. Changes are in sync via iCLOUD
- I start my MacBook , open the file said document , realise that WIFI is switched off , files open up with -55 notes (as expected) I immediately close the document without saving .
- I start wifi on MACBOOK wait for sync , but the file has -55 notes ,
- Mac mini also shows the same file
Questions
- Can I recover ?
- How to avoid situations like this in future ?
- Is ICloud not stable as sync solution?
