Is there a way to sort a container by notes that I designate that begin with “ii”?
I typically have notes notes I consider important as beginning with “ii”? Is there a way to use a primary or secondary sort to allow these documents to be listed first? For example using regex: “^ii”. I realize I can easily create an agent to do this, however, was curious if I could use a sort method instead.
For example,Sorting a container in a structure something similar to this:
ii x note
ii y note
a note
b note
c note
d note
Thanks in advance
Tom
