Bringing notes over from Devonthink into Tinderbox works pretty well in the current version of TBX 7.3.1.
It automatically displays the following KeyAttributes:
URL (populated with the backlink to Devonthink [which actually should be renamed to DT_URL, I suppose])
SourceCreated (displaying when Source was created in Devonthink)
SourceModified (displaying when Source was modified in Devonthink)
Then there is the SourceURL which is not auomatically set as KeyAttribute --> but it should, I suppose; AND: it should be automatically populated with – as the name of this Attribute implies – the URL of the original note in Devonthink … but it does not.
The URL attribute of the container is filled by Bookends. So it is good that the URL of DT’s folder is kept in DEVONthinkGroup. Unless Bookends starts using the ReferenceURL attribute.
I meant to write if Tinderbox used the ReferenceURL attribute for the URL imported from Bookends. I’m sorry. But I think it’s better to keep the URL of the container for Bookends, and the DEVONthinkGroup for the URL from DT. Besides that, I also look forward to get clickable URLs in the notes imported, as well as tags. And if possible, to be able to sync from a secondary folder, so that they can be kept in “/Content”.
