Toolbar on by Default
(Michael Macias) #1
Is there anyway to enable the toolbar so that it is on by default? I just want to be able to open the application and go at my work not having to enable the toolbar every single time I open a file or group of files I work on every single day. I have been waiting years for this feature or option any help would be appreciated!
(Mark Anderson) #2
I don’t believe there is a built-in method for that, so you might want to email that in a feature request**. The toolbar exists mainly, I suspect, as it’s part of the underlying frameworks. There are only 3 controls:
  • Colours. I’ve actually no idea what this controls as most Tinderbox colour controls invoke the system colour palette directly.
  • Fonts. As easily called via Cmd+T shortcut.
  • View type. Right click the selected tab’s tab label to give a pop-up of alternate view choices.
** I’ve not time to test in detail but it might be possible to use a custom config.xml to set this - I’d email tech support to see if that’s possible.
(Paul Walters) #3
The toolbar can have whatever shortcut you want to give it. I believe the default is ⌥⌘T
