Following Michael’s instructions until about 6:19 into it. At that point I just want to enter text into the note “On note-taking workshop.” I can’t get to text in the right hand panel (in map mode). I switch to outline mode and am able to enter the text, which then appears on the note (as illustrated in the provided link). But from there in either Map or Outline mode I can’t get to the text. I must be missing something simple. Is there a keystroke combination that takes you from the note title to the note text???
Thank you
Doug
