Which value(s) for $EndDate?
(Andreas Grimm) #1
What am I doing wrongly?
if($Checked=true){$Badge=Check mark; $EndDate=now} else {$Badge=clock; $EndDate=never};
Using values such as “now/today/current” always results in $EndDate being updated every minute; which, of course, I don’t want. I just need to log the $EndDate and then have it remain unaltered.
Ideas?
Cheers!
(Mark Anderson) #2
Um , that code looks wrong. Strings are quoted (and built-in badge names are lowercase):
if($Checked==true){$Badge="check mark"; $EndDate=date("now")} else {$Badge="clock"; $EndDate=;);
(Andreas Grimm) #3
well, @mwra, the code you kindly provided does not do the trick as far preventing $EndDate from being update every minute is concerned.
And, surprisingly, badge names work, too, if not lowercase and they don’t seem to need “quotation marks” either. Strange? Or just forgiving - codewise?
(Mark Anderson) #4
The latter, or in relation to quotes. The badges is interesting as I previously understood them to be case-sensitive. I suspect they are but if no match Tinderbox probably silently tries a case-insensitive match.
I didn’t have a chance to build a test for your code last night so my post was just testing for a code syntax error.
I think the functional error is your ‘if’ test. I suspect you want to only set the current time if $EndDate_ is not already set_. If so, your test should be:
if($Checked==true & $EndDate!="never")...
That way, checked notes with an EndDate aren’t reset.
(James Fallows) #5
In addition to @mwra’s always-authoritative advice, there’s another trick, just in case you (@andreas) are not aware of it or have forgotten about it. It’s the |= operator, the “pipe” symbol followed by the equal sign.
If the action part of your agent says the following:
$EndDate|=date("now")
Then the value for $EndDate will be updated only if it hasn’t already been assigned a value. Otherwise the value remains what is already there. It’s a different way of testing for an empty / default-value / unassigned field (recognizing slight differences among these).
The way I think of the |= operator, which I use all the time, is that it assigns a value where there isn’t one, but it doesn’t mess up any value you have intentionally assigned. aTbRef has the more detailed explanation here.
(Andreas Grimm) #6
it does work just as you said, @JFallows, and just as I need it to. Thanks you!
