Width expanding to fit Name?
Is it possible to get the width of a note in map view to increase automatically to fit round the Name, instead of getting the Name to wrap?
Expand Horizontally.
Thank you, that is a great help – but is there also a setting that will allow a NEW note to expand while you are typing the Name? Or is it only possible to adjust the width afterwards?
See Edit > Document Preferences
Ah, thank you. I’d forgotten that.
