The notes in the Chinese input state are lost
Recently, I was writing on a map. I wrote about 1000 words in the text window of a note. I used the Chinese input method. When I was resting, I left the macbook and the macbook went into sleep mode.
I use Baidu Wubi input method to input Chinese.
Afterwards, I go back to my macbook and wake up the screen. I saw that the input method has some Chinese content, which is roughly similar to the picture below. However, I pressed the Esc key to try to cancel the input or click the mouse elsewhere. At the same time, this note disappeared and disappeared.
I press command+z to undo, but I can’t undo it.
Cannot undo, retrieve lost notes
After the accident of the previous Chinese input method caused the note to be lost or accidentally deleted (it needs to be specially explained, I did not press the delete button), anyway, this note was lost due to an unexpected bug.
I pressed command+z repeatedly and couldn’t get back what I lost.
It is worth mentioning that the undo of command+z is very stable in ithoughts, and in most cases, it can restore accidentally deleted notes infinitely. -
The unexpected crash of the new version
Tinderbox 9.5.1, more frequently than earlier versions, unexpectedly crashes, the program will exit, and notes will be lost accordingly. -
The crash of importing too large opml
When I try to import a large opml file, tinderbox will fall into a state of suspended animation, which will last for a long time, and even cause the program to exit in severe cases.
Among the above four reasons, the instability of tinderbox itself and possible conflicts with other programs will lead to the loss of notes.
I think tinderbox should add a preventive design, that is, a trash can, or version control, so that users can easily retrieve lost content.
I also mentioned the design of the trash can in an earlier post. Other users suggested regular backups. This kind of regular backup is preventive, but this preventive work must be done manually by the user.
Scrivener also has preventive design, trash can and backup options, and a copy will be automatically backed up when exiting scrivener. With this preventive design, my sense of security is guaranteed when I use scrivener.
But in tinderbox, I often feel uneasy about losing notes. This happened not once or twice, but many times.
I think tinderbox should add a precautionary design:
- Enhance the ability of unlimited undo. Unexpectedly lost data should be able to roll back infinitely through command+z, but this ability is weak and insufficient.
- Increase the trash can. Accidentally lost, accidentally deleted data can be found in trash.
- Regular backup function. Automatically back up a tbx file by date when quitting tinderbox.
