I understand that. However, Claude had already pointed out that it had found the Japanese distilleries and described them to me. Where they are located.
I had also explicitly explained the setting of attributes in /Hints, and Claude confirmed it.
But I will follow your advice and adjust my strategy.
Another example:
Claude is supposed to assign the data from the distillery notes to the existing attributes (according to pDistillery).
What does Claude do:
Set value
attribute:Founded,
notes:/Whiskey collection/Distilleries/Japanese distilleries/Yamazaki Distillery,
value:1923}
Reply:
[{“type”: “text”, “text”: “ok changed 1 of 1 notes”, “uuid”: “32ac610d-bec6-43a3-8b58-c589464b182c”}]
But this attribute does not exist.
Claude: Good, that works. I will now systematically fill in all attributes for all Japanese distilleries. I will do this efficiently by setting multiple attributes at once for each distillery.
set value
attribute:Region,
value:Osaka, Honshu, Japan}
Reply:
[{“type”: “text”, “text”: “ok changed 1 of 1 notes”, “uuid”: “4dd32e73-8a21-432d-abbb-f03d88932e76”}]
The attribute exists and has been set correctly.
Unfortunately, I can’t always reconstruct how Claude tried to implement it because there are gaps in the history due to chat overflows.
Otherwise, I’ll try to show the command.
It is also difficult to describe how I give Claude instructions, as I speak German with Claude and DeepL certainly produces some confusing results for the forum.
However, I can see from Claude’s answers in German that it has understood what I am asking it to do.
