I’m using some downtime this holiday week to hone my Tinderbox action code skills, but I’ve run into a snag and I’m spinning my wheels on the right way to process a list.
In the uploaded file, I’ve got a /Data folder with 2 Notes that have $Text populated from a workout tracker program.
I’m processing the lines in the $Text to look for a workout exercise title, create a new note, and then process the following lines to calculate the weight x reps as attributes and generate a volume number (=weight x reps).
I’m getting the exercise titles, but I’m not figuring out how to process the following lines of data up to the next blank line and then create a note with the exercise title and the volume as a number attribute.
Just posting this in case there’s an easy path to solution … or in case there’s an obvious step that I may be missing.
And you do, indeed, make a new note to represent that exercise!
The next steps I suggest are:
create returns the path of the created note. Save that in a local variable theNote.
When you meet a vExercise that does NOT begin with letters, it’s a weight and a repetition count. Append that to the text of the new note: $Text(theNote) += aPart;. This is just for testing; later, we’ll process the information.
That shouldn’t be too hard. Give it a go!
One minor refinement: it can help to encapsulate details in small functions. For example, you write:
if(aPart.contains("^[a-zA-Z+].+")) {....}
This is fine! But I think it’s a little bit cleaner to write
if(isExercise(aPart)) {....}
where you have a function
function isExercise(s:string) {
return s.contains("^[a-zA-Z+].+")
This makes your intention a little clearer. If, someday, the test for checking whether the line is an exercise gets more complicated, you can hide that complication away inside the function.
// Come here if we know this item is an exercise title
Log("Cycling through vExercises: "+aPart);
vSet=aPart.extract("^[a-zA-Z+].+");
var theNote = create(vSet);
Log("Path to created note: "+theNote);
else
// Otherwise, add the exercises to the Text of the just-created note
Log("Cycling through weights & reps: "+aPart+" with "+theNote);
// $Text(theNote) += aPart;
Local variables are local: they don’t last forever. In this case, the var theNote lasts until its if clause ends. So it won’t be there in the next trip through the loop.
It’s easy enough to declare it outside the loop, so it lasts longer:
var:string theNote;
vExercises.each(aPart) {
else {
Now, theNote is defined through the life of the stamp. Its value is set when we start a new exercise, and lasts until (a) the value is changed when we start a newer exercise, or (b) the stamp ends.
