There are also a lot of recent fixed (typos/corrections) and improvements to text.
Please continue to report any errors, including broken links/images. There are a lot of notes in the site and Iβd rasther get a flase report of an error than none at all.
care should be taken if using key strings that container other than: A-Za-z0-9, hyphen, underscore or space. There is no design intent to support any possible character string, though accented characters and Unicode characters for major languages should be OK. If needing to use key names with things like regex special characters in them you are advised to test them in a small test file first and only implement them once happy there are no unexpected effects.
multi-item values (i.e. lists) areβas at v9.2.0βnot yet supported. A possible workaround is to swap out the list demiiter, e.g. βwinken;blinken;nodβ β βwinken#blinken#nodβ. Until there is support for accessing a single item in a multi-item value, it is necessary to read the value and process the list therein. so, it is trivial work to swap the delimiters back once read from the dictionary, e.g. βwinken#blinken#nodβ β βwinken;blinken;nodβ.
