- If I want to use the TimelinesStart and TimelineEnd to constrain the display are they applied to the container with the timeline notes only, or must they be applied to the container and the notes?
- In a note that is within the timeline container I’ve added the attribute TimeBandLabels and inserted a value. For some reason the Band Label doesn’t appear on my timeline. If I’m trying to show a Time Band Label is there anything else I need to do?
- If I want to show the start date of a note on the timeline can I display it automatically or do I need to write it into the note title?
Thanks
