I saw some previous posts but couldn’t figure out a method that works. “I have $DOB as a Date attribute and $ClientAge as a String. I want to calculate and display age as ‘9 yrs 4 mos’. What’s the correct action code?” Many thanks!
function age(bday:date) {
var:date today = date("today");
var:number totalMonths = (today.year - bday.year) * 12 + (today.month - bday.month);
if (today.day < bday.day) { totalMonths = totalMonths - 1; }
var:number ageYears = floor(totalMonths / 12);
var:number ageMonths = totalMonths - ageYears * 12;
return ageYears + " years " + ageMonths + " months";
Claude Code did almost all the work here. It is a bit uneasy about saying “6 years 0 months”, as this does, or “0 years 4 months” for that matter. Those can be fixed easily, but this keeps things simpler.
Thanks so much. I’ll look up how to enter this function so it appears document wide.
Assumption: partial months are rounded down. 5 years 6 months is any duration between 6 months and zero days and 1 day less than 7 months.
Try this TBX: Age-maths-1.tbx (114.8 KB)
Open the TBX, select the 3 text notes and then use the Stamps menu to apply the ‘Get Age’. Then inspect the $Text of each note and check the result.
In each test note the Date of Birth is stored in $StartDate and which is set as a Displayed Attribute.
how about:
$MyAge = floor(days(date($MyDOB), date(“today”)) / 365.25);
and with formatting:
var totalDays = days(date($MyDOB), date(“today”));
var yrs = floor(totalDays / 365.25);
var mos = floor((totalDays % 365.25) / 30.44);
$MyAge = yrs + " yrs" + (mos > 0 ? " " + mos + " mos" : “”);
