If I select a note in, e.g., table view and then change to map view in the same tab, the selected note may be located outside the current field of view. Is there a way to refocus the view point of the map view to have the selected note in the center? It would be much easier to find it using such a command if the map view is rather large.
Blind type the name of the note to scroll to it.
