Changing tag names
I accidentally made two similar tags in a document: USA and usa.
I want to make all of them read the same: i.e. usa.
Any way to do that
Thanks
Easy!
Make an agent:
query: $Tags.contains("USA");
action: $Tags=$Tags-"USA"+"usa";
In other words, find all the notes that have the. tag USA. When you find such a note, take “USA” out of $Tags and add “usa” to $Tags.
Thanks!
@eastgate solution is great. Here is an alternative approach.
$Tags=$Tags.lowercase.unique.
This will put everything in tags to lower case and then force this list so that are only nique values.
NOTE: this assume you want “everything” to be lowercase in $Tags, not just “usa”.
Since $Tags is a set, I believe you don’t need .unique.
You’re right. I was thinking it was a list. :wink:
