I want to create a list in a note with checkboxes on the left side of each item. Can this be done in tbx?
Thank you
Thank you
Yes (in v10.0.0+), see In-text check-boxes.
You can do this:
Note: as at v10.1.2b710, if the first item (character) of $Text is a checkbox the checkbox is lost when the note loses focus. To avoid this, type a space before adding initial checkbox.
My test: Checkboxes.tbx (101.8 KB)
@mwra Thank you! Works nicely!
