I’ve updated my notes on the var
operator for variables: var.
Most variables, except Number, Date and Boolean types are actually based off string so the issue I’m updating for is moot. But—and since discovery (as at v9.6.1) this will likely be updated—declaring a typed variable, e.g. a Number-type, does not set a default value. Thus:
var:string vString; // value is ""
//but
var:number vNum; // value is "". Really?
Yes, so especially when using a Number-type, seeing a default value is a good idea, i.e
var:number vNum 0 ; // value is 0
This matters if using a user-set counter when an iterating a loop:
var:number vCounter;
$AList = collect(children,$Name);
$SomeList.each(anItem){
$Text(/log) = $AList[vCounter];
vCounter+=1;
For the first run of the loop, vCounter is ""
so $AList[vCounter]
returns … nothing. The counter setting code at the looop end adds 1
. So, on loop #2, the value fetched is $AList[1]
and the result is as expected.
As noted, this will likely be resolved in future version so that using an explicit var:type
declaration will both set the type and that type’s default. IOW, var:number vCounter;
would then set vCounter as
0`. But, as at v9.5.1 this isn’t so.
Other data types are less likely to be problematic in the interim. But, until then if using Number type variables, it is a good idea to explicitly set the type default of 0
(zero), i.e.:
var:number vCounter = 0;
Suffice it to say I tripped up on this recently and spent a lot of time chasing the wrong causes until the penny dropped as to the real cause.
