Is there a designator to collect every name of every note, even on root? Children, descendant, etc. would not work? What is the designator for root?
Have you tried βallβ?
No, thanks! Worked.
BTW, in case anyone is interested.
Since spellchecking does not work in note names, I collect all the note names into the text of a note βSpelling,β with a stamp. I add β[[β before the name.
Spellchecking works in $Text.
If I find a note with a misspelling I complete the the ZipLink action by adding the closing β]]β to the end of the offending note.
I can now click on the note and go fix the spelling. I can then click ββ to navigate back to the spell-checking note.
Here are samples of the action code for your stamp:
If you are root and want to look at all:
var:list vList;
vList=collect(all,$ID);
$Text="";
vList.each(x){
$Text+="[["+$Name(x)+"\n";
If the spelling file is a child of another note, e.g. and article, use:
var:list vList;
vList=collect(descendants(parent),$ID);
$Text="";
vList.each(x){
What a great idea and example! Thank you!
Iβm glad you like it. BTW, I just edited the message to add the stamp code.
