I searched and found no answer: is it possible to create user attributes with action code? And can I test if an attribute is already there?
Not yet, though you can create them from a script, which you can invoke from an action.
Do you have an example of this script?
just a quick reply: with AppleScript you have the “make” command to create a new attribute.
This should work (not tested!)
tell its document "testCreateAttribute"
set myNote to note named "Demo"
make new attribute with properties {name:"demo"}
set value of attribute named "demo" of myNote to "here I am"
end tell
end tell
P.S.: tested - worked
