When I type [[<test::success]], it does create a new note ‘test’ with a backlink. However, the text in the ‘test’ note starts with a colon i.e. :success.
Why might this colon be appearing on the text in the new note?
I am using the latest version of Tinderbox and MacOS.
The method can create backlinks from the destination note. [[]] will create a link to “that note”, and then will append the name of this note to the text of “that note” and link the name back to this note. The mark-up needed is used as a wrapper around the entire input string. Thus:
[[<New Idea>]]
…will create a new note called ‘New Idea’ and link to it. If this method is mixed with other syntax variations, like so:
[[<New Idea|great idea::Recent innovation>]]
…will create a new note called ‘New Idea’ and link to it via anchor text ‘great idea’ and add a backlink with the anchor text ‘Recent innovation’.
IMPORTANT: note how the closing ‘>’ comes at the end, immediately before the closing ‘]]’ and not before the ‘|’ as might be assumed if all the different parts of syntax were just chained.
So unless the new not is meant to be called <text rather than text then the missing closing > in the OP’s examples [[<test::success]] is aslo a factor.
