Curiosity Question re Containers
Just wonder why some containers have their title appear at the top and some appear at the bottom. It must indicated something… can’t quite figure out what.
Agents have their title bar at the bottom. Containers have the title bar at the top.
Thank you.
A graphical summary, for later readers.
In map view:
In Outline view and views using Outline-style icons:
Note in the latter how the map style of thicker bar at top in the icon is used for notes and normal containers whilst agents have a thicker bar at bottom.
[Note to self: I think this warrants an explicit new note in the aTbRef section on Map view container types.]
