Another demo of v9.1+ features by @eastgate
xbuilder.tbx (205.8 KB)
What it does:
Constructs an interesting network inside a container
Techniques:
- creating notes on demand
- adjusting their layout and appearance
- linking them (this was tricky; I see the need now for a simpler approach)
Look at: /Hints/Library/builder
To try it yourself:
See the final lines in the library. See the result in map view inside /Demo.
(Note that if you reduce the number of notes, you’ll need to delete the notes inside the container before running this)
