Export To Featherwiki
I tried to figure this out on my own but I’m a little stuck, please. It comes down to my not fully grokking HTML export templates.
Objective: To create an export template that will export to Featherwiki.
What is Featherwiki? It’s Tiddlywiki but really pared down to a much smaller size. The index.html file is usually less than 1 MB.
I’ve hunted around the forums and came across something @eastgate posted years ago about using ^include. I tried to figure out where to put ^include but for the life of me I haven’t actually figured it out.
I also took a look at a file posted several years ago that had an export template that exported from TBX 7 to Tiddlywiki 3. But a lot of the stuff has since been deprecated. And to throw a spanner in the works, Featherwiki needs Javascript. I’m not sure what the implications of that would be for a TBX export template.
If someone who knows more about this could give me a few pointers, I’d really appreciate it!
I’ve attached a sample file. It’s not much help though I’m afraid.
Thanks a lot.
TBX 10 to Featherwiki.tbx (294.1 KB)
It appears that Feather Wiki has an official import plugin that supports importing from plain text files (or HTML or Markdown). Why not use that feature and just use Tinderbox’s generic File > Export to create the file(s) for import into Feather Wiki?
If that doesn’t work or if there’s more to this problem, could you explain in more detail exactly what you’re trying to export.
This solved my problem! Thank you so much :slightly_smiling_face:
