Problem: Collect all the special passages from multiple notes, where the special passages (no longer than a paragraph) have been set off by a marker, in this case #.
This seems to work:
I create an agent called Juicy Bits, which collects all notes containing the marker. This agent has the following Rule:
I’m now convinced that there ought to be a way to collect highlighted passages. This will take a couple of weeks. (I’m not yet sure whether we really need to distinguish “red-highlghiter” and “yellow-highlighter”: opinions on this are welcome.)
That is exactly what the action code example and the AppleScript above do. Easy to use. Wonder if you’ve had a chance to try them?
I find it much easier to just apply a style via command-b or command-i via the keyboard rather than type in markers, but it will work either way (though the end marker should be different from the start marker).
@eastgate Will there there be a way to apply colors to text as easily as selecting and typing command-b or command-i?
There are shortcuts for coloured highlights (Style menu), but I believe coloured text still requires the OS Fonts palette. It’s worth looking at the app’s existing shortcuts as many choices are already in use.
Thanks for that! I’ve haven’t much ventured deep into those Format submenus so as to reach highlighting, and forgot that was there, I think partly because I once tried highlighting and found it illegible under a dark color scheme.
On my machine the built-in shortcuts for text color work well, now that I remember they are there.
I see there is now a $String.following, which grabs all occurrences.
Maybe $String.between would be what we are talking about here?
The latest backstage release has native support for extracting highlighted passages — not precisely the same as bold text, but pretty close. @gleick : would love to know what you’re working on, if you’re at a stage where you can talk about it.
