ham
(Takeshi Hamada)
1
In order to set the default font for the Adorment title, I opened Modern.tbc and wondered how to change it.
<mapfont>IdealSansSSm-Book</mapfont>
<mapfontsize>16</mapfontsize>
<textfont>MercurySSm-Book</textfont>
<textsizenew >16</textsizenew >
<mapbackgroundcolor>gray</mapbackgroundcolor>
<mapbackgroundcolor2>gray</mapbackgroundcolor2>
<mapbackgroundpattern>plain</mapbackgroundpattern>
<textcolor>black</textcolor>
<textbackgroundcolor>white</textbackgroundcolor>
<maplinkcolor class="all">black</maplinkcolor>
<darkoutlinetext>true</darkoutlinetext>
By the way, the description “AdornmentFont” did not change.
mwra
(Mark Anderson)
2
[edit]
Removed original post as incorrect - see next answer in the thread.
eastgate
(eastgate)
3
No need to fiddle with XML of either color scheme files or Tinderbox files!
The attribute you want to change is $AdornmentFont. Change the default value of any attribute in the System Attribute pane of the Document Inspector.
mwra
(Mark Anderson)
4
I’ve updated my Notes on $NameFont to cross-refer to optional use of $AdornmentFont.
Not sure how I overlooked that (as $AdornmentFont arrived in v7!)
ham
(Takeshi Hamada)
6
I see, Thanks for your support!
