I am a newb to posters but have found an app that exports in a graph format I am also new to using. I think Posters will help here but have no clue how to start or what to use…
Simply stated… this app allows export in GraphML or GexF format… is there a poster methodology for maps what will help me visualize it?
thanks
Tom
Are you saying to want to ‘export to poster’ in Tinderbox using GraphML and GexF. What sort of data are you trying to graph—do you have a particular outcome in mind?
The best approach is to find an example of these formats to web page display and then reverse engineer where Tinderbox input might go. A quick google suggests there are solutions but not simple.
For GexF you might do better to pass your data as note/edge files to Gephi and have it export the data via it’s Sigma.js plug-in †. Note the latter is an incomplete (summer intern!) project so you amend the default output you’ll need to read up on sigma.js documentation. do-able but unless already expert in sigma.js, a non-trivial amount of work. You might find this tutorial of use, if only to gauge the difficulty of the task.
†. This is how I made this demo (Tinderbox export of node/edge, import to Gephi, configure graph, export to sigma.js. IIRC, it was a lot of work and I gave up trying to fix bugs in the sigma.js implementation.
I am just exploring the export format of another program and wondering how I can view it in tinderbox. The graph program can export in GraphML, GexF for to view its graph (its got json and csv) for its text and data but I would like also to view its graph in tinderbox. I am just exploring if it would work.
Ok, let’s say I export its graph data in GraphML or GexF format. Would I be able to paste it in the text field, then use a posters template to view in map view? I think this is what posters are for for map view… what I do not know, is what url you could use to view it? Is GraphML and GexF fairly standard that I could point it at the correct url and ‘expect’ it to work. Probably not. If not, I will not invest the time. Just asking the forum to others more knowledgeable about these formats I have never used before.
thanks in advance
Tom
Almost certainly no, at least not that simply. Not least you’ll need to find the libraries that enable web display of this data. They aren’t web-native formats, it is a lot like using inline SVG to draw a diagram. My quick look at Google earlier suggests it is do-able, but not in a simple ‘just use it’ manner but rather it probably requires a reasonable degree of web/JavaScript skill.
Graphml in gephi?
this is already in deep water for me… sounds like I will stick to csv and json.
Thanks
Tom
