Hi all,
This is likely to be known by many but it was news to me. In the following I describe a nice workflow.
In Obsidian, use the plug-in “Apple Books - Import Highlights”. Use ⌘ P, search “Apple Books” and select one or all of your ePub-books that you want the plug-in to work on. Each found Highlight/Annotation will be collected in a block containing;
Chapter
Context (if supported in the book)
Highlight
Annotation note (if any)
Link to ePub-book original highlight.
The result is collected in a folder “ibooks-highlights” by default. There is a file for each book in the folder.
Moving a book file to Tinderbox and performing an explode on the argument “----” will create a note for each Highlight/Annotation. NOTE, the original file is a Markdown file, so all the notes should be set to Markdown prototype.
Now there are two ways to set the desired prototype:
In the Explode pop-over dialog, set the Action box to $Prototype="Markdown";, but note the latter code is only remembered until the document is closed.
Set the $OnAdd action (via the attribute or using Action Inspector, Action sub-tab) to $Prototype="Markdown";.
Note that the Exploded Notes prototype use used for all Explodes, so if you do Explodes for different purposes, this approach may be less useful as all Explode-created notes with get the Markdown prototype.
