I’m running the following RegEx in extract all extractAll("\[(@.*?)\]"). Is there a way to have extractAll() return the $1 rather than the $0 value, i.e, the value between the ( )?
If you just want to find the @.*? pattern you might try
which will ignore the opening and closing brackets.
Or even this
which just finds the @... strings, makes sure to only include strings that have a closing bracket, and ignores the closing bracket in the output.
Great suggestion! Thanks. ![]()
