In some text I’ve imported there are various occurrences of “%%” throughout the text.
I would like to replace each occurrence of “%%” with a carriage return.
Using the Find and Replace menu item I’ve been able to find each occurrence of “%%” but don’t know what to put in the Replace field to replace it with a carriage return.
I’ve already tried “\n” and “\cr” without success (“%%” is just replaced with those characters).
I’ve also search this forum, the web, and the online documentation without success.
I created a stamp like you suggested (see screenshot below) but whenever I apply it to a note the entire text disappears instead of being replaced (it happens whether I pre-select the entire text or not).
@eastgate - Thanks. I’m aware of how far behind the current version I am. Plan on upgrading at some point but wanted to see if if Tinderbox was appropriate for a project I’m working on (looks like it might be).
Testing out your project with the current version would both assist the forum in pinpointing any issues you have, and also ensure that you’re leveraging the most recent developments in the software - there have been MANY since ver. 8.7.x.
Unless you’re using an antiquated MacOS version, there’s no reason not to download and use the latest demo from www.eastgate.com. Presumably, your currently installed 8.7.x version is also functioning in demo mode.
