How do I center a note window?
Hi! I was wondering if it was or would be possible to make a note window, when using the keyboard shortcut alt + command + X, be in the center of the file, like in the screenshot below? I know there are applications to do this, but it would multiply keyboard shortcuts and would be counterproductive. Thanks for your suggestions.
It’s not possible in Tinderbox right now. I think it might be possible with Stage Manager, part of macOS.
A problem arises when there are multiple text windows. It’s probably unwise to place them all at the same place.
Hi Dominique
I do this with 2 apps.
Moom: which assigns shortcuts to “spaces”/desktop areas (desktop-real estate) from your screen desktop. Very customizable, WHERE you want the window to open with the shortcut
Keyboard Maestro: create a chain of actions with keyboard maestro
  1. Trigger the macro with a keyboard shortcut you choose
  2. Let KM open the tinderbox file you want
  3. Fire off the Moom shortcut you created earlier to place the window where you want
    Keyboard Maestro 11.0.4: Work Faster with Macros for macOS
Here is my example which will mean nothing to you except to show you how I did it… my shortcuts are specific to my system. The grayed out are inactive parts of the macro
A system like this will allow you to place any ACTIVE window, anywhere you want with a keystroke.
There are other apps similar to Moom, it is just one I have used for years.
Keyboard Maestro is an app I have grown up with. Its like Applescript for non-coders, like me.
Cheers
Tom
Thanks Tom for the suggestion. For now, I’m using a shortcut with Magnet.
