How to call function in a note
I ‘created’ a addTax function in note /Hints/Library
function addTax(price) { return(1.18*price);}
Then I created an attribute Test2. The $Test2 is set as number.
I created a note in the ‘root’ directory. I then added in the Rule:
$Test=addTax(5);
However, the $Test remains 0.
Where am I going wrong?
Thank you!
*souced from a webpage
Is $Test a user attribute? Or only $Test2?
I ‘created’ an addTax function in note /Hints/Library
$Test2=addTax(5);
However, the $Test2 remains 0.
Thank you!
*sourced from a webpage
Sorry! Typo. It is $Test2
It is $Test2 (rather than $Test).
Seems to work for me: test price-test.tbx (160.3 KB) based on the info above. The test note is ‘zz’. The function is in library ‘tax test’. The addTex() code worked as typed but I tidied the formatting of it up a bit for clarity.
Funny, I just created a demo too.
@naren17, see attached, there are several element to adjust.
FunctionTest.tbx (180.1 KB)
@mwra and @satikusala, Thank you for your example files. I reproduced your files and got them working.
I dug to find my mistake. I pinpointed the problem: I had not left a space after the “return.”
Cheers!
Thanks. For later readers, return is one of the few action code operators that doesn’t take parentheses after it. Accidentally writing the function in this form:
makes the app’s parser—the app reading/interpreting that code—think that the returning statement is in fact an—illegal—input argument for the return operator. The minimum fix required is to insert a single space after return:
function addTax(price) { return (1.18*price);}
This now indicates parentheses around the price calculation and signals to the parser—if necessary—to multiply price before returning the result.
A more customary—but not required—method of writing such a function would be:
function addTax(price){
The changes are essentially ‘white space’. They don’t alter the process but may add clarity, especially those new to action code and/or to coding more generally.
†. When I wrote earlier I’d tested the function ‘as is’, I must have reflexively added the missing space without registering that I had done so. As a TBX is not some high-volume/speed process, writing code in minimal space if often a vector for error. A few slices or line breaks can do much to aid oneself when getting code to work.
@mwra Thank you! Adding a space after return sorted the problem!
