Hello,
Does anyone know how to make EagleFiler record links work?
If I copy a record link in EagleFiler and paste it into, say, TextEdit, I can click on the file link that is generated to navigate to that folder or record. Examining the link shows it is of the form:
x-eaglefiler://open?library=~/Documents/Personal%20Reference/Personal%20Reference.eflibrary&recordGUID=cHyrW_H3Q4u9KzVCfjU8eA
However, if I paste the link into TB, I get something that looks like a link and acts like a link, but doesn’t navigate to the EagleFiler element.
However, if I do the same thing with, say, an Omnifocus task, it works (in TB), but the link is of the form:
omnifocus:///task/dVaJ_ApPgxW
So, perhaps this is a multi-library problem and TB can’t handle the “open” command in the link?
Thank you,
Rob
